panorro
Program SP605 from SPI Winbond W25Q64VSFIG
I'm using a SP605 board, and I've generated a .mcs file, that I loaded to the Winbond SPI Flash using iMPACT.
I'm not sure if I told SPI to load FPGA in x1 mode or in x4 mode (because I don't know how to set it).
When I set M0=1 and M1=0, and I turn on the board, FPGA must program itself reading from SPI Flash memory. It works, but it takes about 5 seconds. Is it a normal time?
I think it is too much time, but maybe it's normal. How can I be sure that my SPI flash memory is loading the FPGA in x4 mode?
thanks,
Jose Luis
luisb
I don't think this is a PCI Express question, the moderator should move this question to another forum board.  Maybe the config forum.
panorro
Ops! Sorry, I confused the section posting. Please move the post to the correct one. Sorry again.
panorro
Well,
I finally could program my FPGA from SPI Flash in quad mode. Now it is faster.
My answer came from: http://www.xilinx.com/support/answers/37626.htm
Sorry again for confusing the section. I wanted to post in "Xilinx Boards and Kits", because it was a question about sp605 board.
bye
