dsakjl
QDMA USER INTERRUPT
we are using QDMA IP version 3 (rev.3) with Vivado 2019.2.
We noticed that a port called "user interrupt" is available
and that it could be used to generate user interrupts.
We would like to understand how to correctly interface custom logic
with that port and what we should do at driver level
(probably in libqdma https://github.com/Xilinx/dma_ip_drivers/tree/master/QDMA/linux-kernel/libqdma)
to make it work properly.
Thanks for the help.
dsakjl
Hello eveyone,
the use of the "user interrupt" port on QDMA 3.0 it turned out to be quite simple.
The port protocol is described in the IP documentation and we had no problems with it.
The unclear part concerned the programmability of the these interrupts.
In particular, the doubt was how to associate an MSIX vector to an handler.
It eventually turned out that it is not necessary to that.
In particular, on PF0 with Xilinx QDMA driver in use, the generated interrupts
overlap with the error, mailbox, and the data ones.
Thank you.
dmsspb
Be noticed what QDMA 3.0 patched with AR 73179 is newer than 3(rev3) 2019.2
dsakjl
Hi dmsspb,
thank you for the response.
Yes, we know that a "tactical patch" (AR73179) is available for QDMA IP and
we already tried it without success.
The point is that the user interrupt functionality doesn't seem very well
documented in the currently available documentation
(https://www.xilinx.com/products/intellectual-property/pcie-qdma.html#documentation).
On the FPGA side the user interrupt port is pretty simple and we have already developed
an IP to generate user interrupts through that port.
On the host/driver side the matter seems more obscure.
Infact, if one look at other special type of interrupts, specifically the error and mailbox ones,
the QDMA IP provides dedicated registers to indicate the chosen MSIX vectors for
those interrupts and to ack them. This doesn't not seem true for the user interrupt(s).
Note that the current QDMA IP driver (https://github.com/Xilinx/dma_ip_drivers/tree/master/QDMA/linux-kernel/libqdma)
seems to support user interrupt(s). In particular, it is possible to specify the number
of MSIX vectors to dedicate to user interrupt(s) and a function pointer to an
appropriate IRQ handler.
However, there is no interaction with any QDMA IP register to inform the IP about these choices.
So, we would like to understand what we are missing.
Thank you.
namabo
any news on this?
We are interested in switching from XDMA to QDMA.
In XDMA we take advantage of user interrupts and, for each user interrupt,
there is a dedicated register to specify the corresponding MSI-X vector number.
Is it possible to do the same on QDMA? How?
dsakjl
Hello eveyone,
Thank you.
Msi-hahaha
How to use an existing driver to call a user  state function。
dsakjl
Hi @Msi-hahaha ,
please, start a new thread in forum with a proper title to permits other to discuss your problem and find a solution.
Thank you.
