jhallsnl
QDMA: Unable to load module
We are trying to load the QDMA module after manually building and installing it. Here is the error when we attempt to load either qdma-pf.ko or qdma-vf.ko:
'ERROR: could not insert module qdma-pf.ko: Invalid module format'
The host system we are using is ARM 64-bit running on Nvidia's Jetson AGX Xavier. Linux kernel version is 4.9.140-tegra.
Has anyone been in a similar situation?
dsakjl
Hi @jhallsnl ,
please can you run the command:
$ modinfo qdma-pf.ko
and share the output?
Regards.
