christian.lambricht
QDMA V3 vviado 2018.3 Example design failed to generate
The QDMa example design in stream with completion didn't want to generate.
# generate_target open_example [get_ips qdma_0]
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'Pf3 Msix Cap Table Offset(PF3_MSIX_CAP_TABLE_OFFSET_qdma)' with value '10000' for BD Cell 'qdma_0'. Entered  Hexadecimal value 10000 is out of range.
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'Pf3 Msix Cap Pba Offset(PF3_MSIX_CAP_PBA_OFFSET_qdma)' with value '14000' for BD Cell 'qdma_0'. Entered  Hexadecimal value 14000 is out of range.
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'Pf2 Msix Cap Pba Offset(PF2_MSIX_CAP_PBA_OFFSET_qdma)' with value '14000' for BD Cell 'qdma_0'. Entered  Hexadecimal value 14000 is out of range.
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'Pf1 Msix Cap Table Offset(PF1_MSIX_CAP_TABLE_OFFSET_qdma)' with value '10000' for BD Cell 'qdma_0'. Entered  Hexadecimal value 10000 is out of range.
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'Pf0 Msix Cap Table Offset(PF0_MSIX_CAP_TABLE_OFFSET_qdma)' with value '10000' for BD Cell 'qdma_0'. Entered  Hexadecimal value 10000 is out of range.
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'Pf2 Msix Cap Table Offset(PF2_MSIX_CAP_TABLE_OFFSET_qdma)' with value '10000' for BD Cell 'qdma_0'. Entered  Hexadecimal value 10000 is out of range.
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'Pf0 Msix Cap Pba Offset(PF0_MSIX_CAP_PBA_OFFSET_qdma)' with value '14000' for BD Cell 'qdma_0'. Entered  Hexadecimal value 14000 is out of range.
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'Pf1 Msix Cap Pba Offset(PF1_MSIX_CAP_PBA_OFFSET_qdma)' with value '14000' for BD Cell 'qdma_0'. Entered  Hexadecimal value 14000 is out of range.
INFO: [IP_Flow 19-3438] Customization errors found on 'qdma_0'. Restoring to previous valid configuration.
ERROR: [IP_Flow 19-98] Generation of the IP CORE failed.
Do you have any idea how to bypass this error?
Best regards,
Christian Lambricht
christian.lambricht
Problem solved by patching the qdma_v3_0.tcl. like below for all physical function.
proc validate_PARAM_VALUE.pf0_msix_cap_table_offset_qdma {PARAM_VALUE.pf0_msix_cap_table_offset_qdma} {
#return [RangeCheck4HexDec 1400 2400 ${PARAM_VALUE.pf0_msix_cap_table_offset_qdma}]
return [RangeCheck4HexDec 10000 10000 ${PARAM_VALUE.pf0_msix_cap_table_offset_qdma}]
proc validate_PARAM_VALUE.pf0_msix_cap_pba_offset_qdma {PARAM_VALUE.pf0_msix_cap_pba_offset_qdma} {
#return [RangeCheck4HexDec 1400 2400 ${PARAM_VALUE.pf0_msix_cap_pba_offset_qdma}]
return [RangeCheck4HexDec 14000 14000 ${PARAM_VALUE.pf0_msix_cap_pba_offset_qdma}]
christian.lambricht
deepeshm
Thank you. We have taken a note; we will investigate and fix the issue in a future release of the tool.
deepeshm
This issue will be fixed in the next release of Vivado. For Vivado 2018.3, please install the patch in https://www.xilinx.com/support/answers/72013.html.
christian.lambricht
404: Page Not Found
coryb
Hello @christian.lambricht,
The AR72013 link is now working as expected in @deepeshm post. I am not sure what the problem was there, but its now public. Sorry for the confusion.
Cory
tankysose
I copy
into vivado tcl console,and input
validate_PARAM_VALUE.pf0_msix_cap_table_offset_qdma  PARAM_VALUE.pf0_msix_cap_table_offset_qdma
the tcl report the error :
invalid command name "RangeCheck4HexDec "
