QDMA driver
Currently, we use QDMA IP in our architecture. Xilinx releases QDMA 3.0 version, and QDMA driver is also released 3.0 version of git hub.
However, due to the internal issue, we are in the process of developing QDMA 2.0 version because of Vivado version dependency. QDMA
driver is not the official release version but the driver is acquired from the web. As a result of review, it seems that there are some bugs
in the driver, so I would like to know if it is possible to request driver 2.0 version which was previously distributed with Xilinx.
Re: QDMA driver
Hi @jungmin_choi_sk
I will check on what version I can access and if I can provide these. Please not that support for older versions would be limited. When you state that you see bugs in the driver is this with QDMA 2.0 and using the QDMA Driver 3.0 and you are expecting that v2.0 driver will resolve these based on version compatibility?
Kind regards,
Gareth
Re: QDMA driver
Hi @jungmin_choi_sk
I have sent you the QDMA ver2 Drivers through our EZMove file transfer application. Please let me know that you have received these and I hope they help you.
Kind regards,
Gareth
Re: QDMA driver
Hello Gareth,
I could get the Driver you sent and I will apply that to our project.
I really appreciate your help.
Jungmin
