markramona
QDMA what is s_axis_c2h_cmpt_ctrl_no_wrb_marker
Vivado 2020.2 seems to have added a port
`s_axis_c2h_cmpt_ctrl_no_wrb_marker`
with no explination of what it does, nor how to connect it if one is migrating.
It seems that the documentation hasn't been updated to match
https://www.xilinx.com/products/intellectual-property/pcie-qdma.html#documentation
Any help on this issue would be greatly appreciated.
venkata
The interface signal to tell the CMPT engine to not send a write to the completion ring when processing a marker is called: s_axis_c2h_cmpt_ctrl_no_wrb_marker.
