03-05-2020 01:31 PM - edited 03-05-2020 01:37 PM
Hey All!
I'm attempting to read and write some bytes in Python to GPIO over PCIe on my AC701.
I've done this same task with the same Python code and it worked. I have since recreated the Project in Vivado and now it doesn't work. Thus I suspect there's something up with my Vivado stuff.
Here's my block diagram and addressing
The device enumerates. When I run the lspci -vv I get the following:
My python code:
import os import mmap os.system('setpci -s "01:00.0" COMMAND=0x02') resource0 = os.open("/sys/bus/pci/devices/0000:01:00.0/resource0", os.O_RDWR | os.O_SYNC) memFile = os.open("/dev/mem", os.O_RDWR | os.O_SYNC) startAddr = 0xe0000000; resourceSize = os.fstat(resource0).st_size print 'size is ' + str(resourceSize) + ' bytes' mem1 = mmap.mmap(memFile, resourceSize, flags=mmap.MAP_SHARED, prot=mmap.PROT_WRITE|mmap.PROT_READ, offset = startAddr) mem2 = mmap.mmap(resource0, resourceSize, flags=mmap.MAP_SHARED, prot=mmap.PROT_WRITE|mmap.PROT_READ, offset = 0) mem1[0] = '\xFF' mem2[0] = '\xFF' #this used to work!!
Writing either mem1[0] and mem2[0] does nothing.
I get an error when I read either mem1 or mem2.
[ 180.156142] nwl-pcie fd0e0000.pcie: Non-Fatal Error Detected
03-05-2020 04:52 PM
03-05-2020 04:52 PM
