Visitor sagasgrt
SRIS support in pg239 PCS's elastic buffer
We are using Ultrascale+ FPGAs and would like to check whether elastic buffer in pg239's PCS can support SRIS, i.e. can tolerate 5600ppm differences. If that is true, how should I configure/enable pg239 into SRIS mode? Thanks
btw, I did a quick search, and found only one similar topic below, but the poster was actually using SRNS in my understanding.
https://forums.xilinx.com/t5/PCI-Express/PCIe-PHY-is-asynchronous-refclk-via-PHY-REFCLK-MODE-really/m-p/916703?advanced=false&collapse_discussion=true&filter=location&location=forum-board:PCIe&q=SRIS&search_type=thread
Re: SRIS support in pg239 PCS's elastic buffer
SRIS is not supported
