opal-rt_fpga_grp
TRN to AXI Migration for Kintex-7 with ISE14.7
Hi everyone,
We're trying to migrate our existing PCIe design (TRN interface) to the Kintex-7. The "7 Series Integrated Block for PCI Express" IP core (v1.11) only supports the new AXI interface. To generate this core, we used the Coregen utility distributed with ISE Design Suite 14.7.
To convert from the TRN to AXI interface, we followed to the letter the "Step-by-Step Migration Guide" described in PG054 (v1.8), page 407. Regarding these Migration steps, one of them seemed a little strange:  is it necessary to change the polarity of signals coming out of port user_clk_out  of the IP core block to connect it to the trn_clk port of our existing circuitry?
Doing so creates paths with a relative clock speed of twice the normal clock rate between sequential elements of the core and our own logic.
Is this a typo on PG054 or is this absolutely necessary? And if required, what is this used for?
 Mike - Member of the FPGA Group, OPAL-RT TECHNOLOGY INC.
pumpkin
I am also confused. Since in TRN and AXI, the signals are sampled on rising edge of clock, why shoud the clock be inverted?
Have you done your migration? I believe the author of the guided didn't do it either.
Xiang Chao
opal-rt_fpga_grp
We did the Migration and it it currently under test. Currently, we do NOT invert the polarity of the signal user_clk_out when we connect it to the trn_clk port of our existing design.. And so far, it seems to be working pretty well.
I really wonder why the Xilinx support people cannot answer this simple question.
Anyway, I will report my final results when the tests will be completed.
Thanks for your reply,
pumpkin
I'm also trying to do the same work, just getting started.
I got another question in the migration guide. It's about the trn_trem_n logic:
this is the code nippet in the guide:
if s_axis_tx_tlast == 1 //in a packet at EOF
s_axis_tx_tkeep[7:0] = user_trn_trem_n ? 0Fh : FFh
else //in a packet but not EOF, or not in a packet
s_axis_tx_tkeep = FFh
Since trn_trem_n is active low, when it is 0, s_axis_tx_tkeep[7:0] should be 0Fh. So I think the code should be:
s_axis_tx_tkeep[7:0] = (user_trn_trem_n=0) ? 0Fh : FFh
Is this a mistake of the maual? Or I made a mistake?
Xiang Chao
opal-rt_fpga_grp
Hello 'pumpkin',
Regarding the equation to generate signal s_axis_tx_tkeep[7:0] from user_trn_trem_n, I beleive that the code provided by Xilinx is correct.
In pseudocode as well as in Verilog, a mux is written as following:
mux_val = mux_sel ? mux_val_if_sel_is_ONE : mux_val_if_sel_is_ZERO;
From UG517, v5.1, p34:
• trn_trem_n =0, packet data on trn_td[63:0]
• trn_trem_n =1, packet data on trn_td[63:32]
Therefore, the following equation for 64-bit interface seems OK  because you want to keep only half the bytes (0Fh)  when user_trn_trem_n is ONE and all the bytes  (FFh) when user_trn_trem_n is ZERO
