Visitor chickenjohn
Two MSI-X interrupts triggers same interrupt handler on VCU118
I have a design with MSI-X capability. There are two interrupt sources in hardware. On the VCU118 board, both of them trigger the same interrupt handler in the driver at x86 host side. On NetFPGA-SUME board there is no such problem and interrupts work fine.
The design has a DMA/Bridge PCIe Subsystem IP. It is set to be Bridge mode. The design is developed using Vivado 2018.1 with AR71169 and AR71167 patched. The MSI-X vector table and PBA are assigned to BAR[3:2](64-bit address). The BAR is 128K and is only used by MSI-X structures. Two interrupt sources are concatenated and connected to usr_irq_req[1:0].
The driver enables MSI-X by pci_enable_msix_range(); A msix_entry structure is initialized, and two different request handlers are assigned to two interrupts respectively by request_irq(); There is no other operations about MSI-X in the driver side.
Thank you in advance for any suggestion.
Tags (2)
Re: Two MSI-X interrupts triggers same interrupt handler on VCU118
Hi @chickenjohn,
Could you provide an LSPCI -vvv of the Xilinx device, and ensure that your usr_irq lines are correctly mapped in the Register mapping of the Bridge?
