02606
UCF for ML505
My project will ultimately use a Spartan-6. However, while I wait for that design to make its way through layout and as a confirmation that I'm not missing something important, I'd like to use my ML505 to get ahead where I can.
Since the ML505 has a PCIe connector, the working presumption is that it works with PCIe. Why is there no UCF file for the ML505 in XAPP1052?
Where can I find the UCF?
Was there a problem in implementing XAPP1052 on the ML505? Perhaps significant enough that I should abandon the effort?
Best of all would be a complete project that I could just drop into the 12.4 tools, check out, and move onto the Spartan-6 where I'd really like to spend my time.
Anybody got one?
02606
Thanks to the subsequent poster regarding XAPP859! Problem solved.
luisb
If you need UCF, I recommend looking at the PCIe example from here:
http://www.xilinx.com/products/boards/ml505/ml505_12.1/pcie.htm
I'm not sure why the ML505 is not part of the XAPP.  The XAPP does have a custom board flow, so you may want to use that flow.
As far as migrating from V5 to S6, I recommend reading the "Migration Considerations" section of the S6 UG on page 163:
http://www.xilinx.com/support/documentation/user_guides/s6_pcie_ug654.pdf
