UltraScale+ PL endpoint PCIe: 4 lane can work but 8 lane can't
On our own hardware board, zu11 is connected to an Intel CPU through PCIe directly at 8 lanes. Intel CPU is root complex and zu11 is endpoint.
PIO demo of IP "Integrated block for PCIe" is used in zu11. When the IP is configured in 4 lane mode, we can find Xilinx endpoint device in Intel CPU by typing "lspci". But no Xilinx endpoint device is found after IP is configured in 8 lane mode.
The configure of IP (8 lane mode) is showd below: (vivado 2018.2)Selection_050.png
The hardware design is showd below:
Is there a way I can find out what's happening in the PCIe IP block? (Like error status)
How can I check the status like "TXDETECTRX" in PL. I am confused becasue there is no PIN called this name. Is it a register in PCIe IP?
This is the GT port name. When inserting ILA, if you check the port connection of GT components in the netlist, you can select the appropriate net.
