Participant bitstreamer
Ultrascale+ Endpoint for PCI Express Root Port Model Location
Where did the testbench for the PCIe endpoint go? It's a PCIe setup as a root port.
It's referenced in PG195, Testbench->Root Port Model Test Bench for Endpoint.
I thought it was at the link below, it's not, it's also not in the reference design in 2018.2. Are testbenches for IP located in a common area?
I'd like to instantiate the Gen 3 PCIe with DMA and get a basic testbench running in linux.
https://www.xilinx.com/support/answers/65751.html
回复: Ultrascale+ Endpoint for PCI Express Root Port Model Location
hi @bitstreamer
After you custermize the IP, you will see a .xci file in Vivado GUI.
Right click on the .xci file, you can select the Open IP Example Design.
Then you will see the RP files location (the "imports" folder). Those files are the testbench mentioned by PG195.
Please see the following snapshot.
Boris
hi @bitstreamer
Boris
