sanjanabikonda
Unable to enable P2P on vcu 1525
I am having trouble enabling P2P on VCU1525. Runnning the command 'xbutil query' displayed the P2P enabled field as N/A .
xbutil queryxbutil query
When enabling the P2P using the 'xbutil p2p --enable', I got the 'ERROR: P2P is not supported on this platform'. Does this error message suggest that my fpga board doesn't support the feature or the host PC has the problem?
Sanjana
anatoli
Hello @sanjanabikonda ,
In relation to PCIe peer-to-peer communication (P2P), please review more info in the below link and see if you can obtain more details about enabling it with this particular VCU1525 card:
https://xilinx.github.io/XRT/2019.1/html/p2p.html
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
