Unable to generate 'Unsupported Request Error'
I have setup with EP card (PCIe complinace customised Exerciser card) connected over PCIe slot at Server platform.
I want to generate and identify UR at Root port side. Looks liek I'm not able to generate and detect UR.
Here are the details:
EP side:
- BAR0 base address mapped to 8750_0000 (at 10h offset)
RP side:
- BAR0 base address mapped to 87f0_0000 (at 10h offset)
- Meory Base Address mapped to 8400_0000 (at 20h offset)
- Memory limit 85f0_0000
I have enabled all registers responsible for error reporting and genertaing at both the ends.
AT what address I should do read operation so that RP should generate UR or should receive UR?
回复: Unable to generate 'Unsupported Request Error'
you  can try to  generate a TLP ,a memory read for example, with poisoned bit set
then you can check Device Status
Thanks. It worked for me.
