johan_d
Upgrade AXI PCIe IP from v2.8 to v2.9
Today I'm running a block design with a memory mapped AXI PCIe IP (version 2.8) under Vivado 2017.2.
I'm trying to move up to Vivado 2019.3 but having issue with the PCIe IP. It can't find the IP and I can't find any way to automatically upgrade it to v2.9 in Vivado 2019.3. I have run the "report IP status" but the IP isn't listed in that report.
Below is a picture of how Vivado behaves when I try to open the block design.
Is there any way to update the IP in the block design without recreating the block design?
venkata
Hi @johan_d,
Vivado 2019.3 does not exist. I believe you meant Vivado 2019.2
The error message says the tool could not find axi_pcie v2.8. As you said, Vivado 2019.2 has v2.9.
Can you provide the steps you follow to do the upgrade from Vivado 2017.2 to Vivado 2019.2?
