Deepthi_Sai
Verilog code for BRAM_SDP_MACRO
Hello sir,
Can I get Verilog Code for RAM_SDP_MACRO which is in the 7 Series integrated block of PCIe. please send the code to deepthisai4312@gmail.com.
deepthi
Hi @Deepthi_Sai ,
You can get the basic template for the RAM_SDP_MACRO in the vivado tool.
Go to Tools --> Language Templates then search for RAM_SDP_MACRO. Select the code regarding to the device used and incorporate the function into the design.
You can modify code according to your functionality and dependence.
Deepthi.
deepthi
Hi @Deepthi_Sai ,
Deepthi.
