Version readback PCIe Endpoint Block Plus
can anyone tell me how to read back the version no. of the implemented core? Is there a Config Space register?
thx,
Michael
Re: Version readback PCIe Endpoint Block Plus
The core does not contain this information built in. In other words, the version of the release is not stored in the logic.
However, the user could impelement this in either a memory mapped register or you might use the RevisionID register located in the Configuration Space.
John
John
Additional question:
is there a report where I can find informations about the implemented PCIe core version/patch?
Michael
When you generate the core a readme file in the core directory that will contain the version info including the patch status if any. This is the only thing I am aware of that informs of the version.
I hear what you are saying though, and it would be handy if there was a way for the implemenation tools to read something out of the core netlist to intepret the version.
-John
