Vivado 2013.4 AXI PCIe IP for Artix 50t scg325 package
I try to integrate the PCIe IP into my design but found no PCIe IP on the IP catalog.  I appreciate if anybody tell me why there is no PCIe IP support in for this package and anyway to get around it.
Henry
Re: Vivado 2013.4 AXI PCIe IP for Artix 50t scg325 package
You will get the IP enabled in 2014.1 which will be released most probably in first week of April
Snapshot from internal build
Hope this helps
Vanitha
Hope this helps
Vanitha
