sjuer
Vivado 2018.3. Integrated Block for PCI Express and Artix in package cpg236
In Vivado 2018.3 7 Series Integrated Block for PCI Express in Vivado 2018.3 not support parts Artix in package CPG236 (I interested in XC7A15TCPG236). But in Vivado 2018.2 it was supported. Should I, because of this, refuse to use Vivado 2018.3 if I need to use XC7A15TCPG236 for PCI Express applications?
coryb
Hello @sjuer,
I have delivered the patch to you via EZmove as well as attached it to this response. It will take some time to get the Answer Record pushed public (which will be the official delivery of the patch.) But until then please let me know if the patch resolves your issue. Here will be the official link when public: https://www.xilinx.com/support/answers/72010.html
I have gone through several example designs in Vivado 2018.3 with this patch using a 15T/35T/50T Artix-7 Device with a CPG236 package and all 3 designs are able to generate a bitstream.
Please mark this post as a solution so we can more widely distribute the patch.
Cory
coryb
Hello @sjuer,
I have reported this issue via a Change Request and the factory is looking into it currently.
Cory
coryb
Hello @sjuer,
The factory will provide a patch to allow the CPG236 package to be used in Vivado 2018.3 / PCI-Express IP. Until a patch is provided, please use Vivado 2018.2.
Cory
sjuer
@corybThanks!
coryb
Hello @sjuer,
Cory
