Vivado Installation Problem
I'm trying to install Vivado Design Suite, and after xilinx installer frame closes, nothing happens.
Updating Windows version will solve the problem.
Thanks!
garethc
Hi @andreipetrascu
Thank you for updating the post and I am happy that this is working now. Note that for any installation/licensing issues in the future can you use the "Installation and Licensing" board that can be found under Vivado RTL Development section. Link below:
https://forums.xilinx.com/t5/Installation-and-Licensing/bd-p/INSTALLBD
Gareth
Versal Blogs
