shreyasshah
Vivado2020.2 PCIe PHY
I am not able to see the PCIe PHY in 2020.2 for Alveo 250 board, I am trying to connect the soft CXL EP IP via PIPE Interface.
Any help?
Shreyas
nmanitri
Hi @shreyasshah ,
Currently, PCIe PHY IP support following device:
Please go with the workaround "r, if a device is selected and has the same transceiver type as the desired device
(UltraScale GTH, UltraScale+ GTH or UltraScale+ GTY), the IP can then be migrated to the
desired part"
Naveen
