Anonymous
Not applicable
Where is the reference CLK in the PCIE design
I couldn't find the diff  signal refclk+ and refclk- in the pcie core  interface. Is it the refclkout  ? And why it's only a single   signal in the interface?I think the PCIE signals in the core interface should be mapped to the fpag pins  directly.
  Did i figure it out?
luisb
Look into the example design and the pins are called sys_clk_p and sys_clk_n.  These clocks go to a differential input buffer that eventually goes to the PCI Express core.
Here's what you'll see in the xilinx_pci_exp_ep.v:
  IBUFDS refclk_ibuf (.O(sys_clk_c), .I(sys_clk_p), .IB(sys_clk_n));
Then sys_clk_c goes to the sys_clk input of the core.
The code may be different if you're targeting different devices, but I think you should get the point.
Hope this helps.
luisb
Hope this helps.
Anonymous
Not applicable
Ok ,thanks. a lot I 've found it. And another question , the refclk+/-  is from host to fpga? or from fpga to host?  Iam confused by the information in web
