Visitor viggy
Windows 10 with XDMA drivers, getting a BSOD...
Has anyone run into this issue? I'm trying to install the example drivers from https://www.xilinx.com/support/answers/65444.html, but get a BSOD on Windows (see attached). I have not modified anything with the driver code...
Thanks!
Viggy
Re: Windows 10 with XDMA drivers, getting a BSOD...
Please do the following steps and share the dump you get from WinDbg tool.
1. Load XDMA example design .bit file into the board
2. Install XDMA drivers
3. Make some XDMA design tests (xdma_teat.exe xdma_rw.exe xdma_info.exe)
4. Reboot the PC and get BSOD issue
5. Power down the board
6. Reboot PC normally
7. Open WinDbg and load MEMORY.DMP file
8. Set "Symbol File Path" and "Source File Path" to appropriate paths
Symbol File Path:
Path to the directory -- xdma_driver_win_2018_2\x64\XDMA_Driver\Win10_Release
Source File Path:
Path to the directory -- xdma_driver_win_2018_2\xdma_driver_win_src_2018_2
