wmsoto
Windows 7 and Windows 10 PCIe drivers for Artix-7
We have a working PCIe single-lane design using the XC7A12T FPGA using Linux. We now have a requirement to use this on Windows7 or Windows10. I see AR# 65444 and got the zip files and noticed there are some sub-folders for windows 10 also.
Just checking if there's anything that would be good to know before trying to implement these project files in our project.
garethc
Hi @wmsoto
We provide these drivers in AR:65444 as is and with our example design we see no issues to note that you would need to be aware of. I hope this helps.
Gareth
If starting with Versal take a look at our Versal Design Process Hub and our
Versal Blogs
wmsoto
My software guy is asking for Windows 10 driver source code. Is this available?
garethc
Hi @wmsoto
Please see Note 1 in the solution section of AR:65444 where you can request access to the driver source code and Windows 10 is included in this.
https://www.xilinx.com/support/answers/65444.html
Gareth
Versal Blogs
wmsoto
