XAPP1052 perl script error
I am trying to use XAPP1052 with a ML555 board and when I get to the part where I run "implement_dma.pl" it fails. I have checked for the correct .ucf and .scr and they are in the correct directories. the error i get in the script is
ERROR: Portability:90 - Command line error: Unexpected argument[7]
".../fpga/implement\ucf\xilinx_pci_exp_blk_plus_1_lane_ep_ml555.ucf" found
Has anyone had this problem before
Re: XAPP1052 perl script error
I found the problem with the initial error: the directory where i had my files had a space in it ('My Documents/...) and the system call did not recognize this, I had to surround each system call filename with quotes.
Now i am getting a compiling error: could not find verilog include file '../../../source/pcie_blk_cf_int.v'
should this file be included with XAPP1052?
I think that pcie_blk_cf_int.v has always been not in the source for either the v1.13 or v1.14 core. .
I think it might be a discrepancy between the xapp1052 source structure and the current one, since the core has evolved so much. I think a safer approach would be to open up the xst file in the core's implement folder and change the one for the xapp1052 design to match that.
I have found both pcie_blk_cf_int.v and use_pll.v specified in the xapp1052’s xst file are missing in the source folder.
