XDMA IP for ZCU102 Board
I'm using Vivado 2019.2 and I cannot find the XDMA IP from the IP catalog. If I create a project using the KCU105 board the IP catalog does includes the XDMA.
Is the XDMA supported for the ZCU102 which has the XCZU9EG-FFBV1156-2-E part on it?
Re: XDMA IP for ZCU102 Board
Hi @abuck,
ZCU102 does not have PCIe hardblock primitives. So, XDMA is not supported.
Please let me know if you still need more assistance.
Romisaa
Don't forget to reply, give Kudo and accept as solution
Hi @abuck,
Romisaa
Hello @romisaas,
Thanks for pointing that out. It all makes a lot more sense to me now.
Advisor
Advisor
You might look at ZDMA that lets you use the DMA engines of the ZynqMP.
DSP in hardware and software
