Visitor joao1996
XDMA and DDR4 MIG (S_AXI_CTRL signal)
I am using the Vivado IP Integrator to create a block design. My goal is to transfer data between the host machine and VCU1525 DDR4 memory. For that I am using the following IPs: XDMA and DDR4 MIG.
The MIG block has a signal called C0_DDR4_S_AXI_CTRL but I don't know where it should be connected. Right now it is connected to the XDMA M_AXI_LITE interface (address 0x80000000). Is it correct?
Thank you.
Tags (4)
Re: XDMA and DDR4 MIG (S_AXI_CTRL signal)
Please refer to:
Page 111 of PG150 describes as "Table 4-19 lists the AXI4 slave interface specific signals. Clock/reset to the interface is provided from the Memory Controller."
And also, there is "AXI4-Lite Slave Control/Status Register Interface Block" section at page 109 of PG150.
