lesjokolat2
XDMA and kernel 5.x build.
Just wanted to give a heads up to people. Hopefully support can review and push.
Alot of issues hadon kernel 5.x with regards to install and build of XDMA drivers have been fixed.
https://github.com/Xilinx/dma_ip_drivers/pull/44
regards
deepeshm
Thank You. We will review this.
lesjokolat2
I have an update on this. I found an error in the make file.
https://github.com/Xilinx/dma_ip_drivers/pull/44#issuecomment-584447315
After this tweak I was able to make and load driver on a 5.x kernel!
