Newbie wonsikleee
XDMA ip driver for two boards
I'm trying to build a xdma driver with two boards.
How I can seperately send data to each board?
Thanks in advance!
Re: XDMA ip driver for two boards
If I do not misunderstand the question, different access is possible if different addresses are assigned to each BAR.
Newbie wonsikleee
Hi, kurihara
I think there are no details for assigning different addresses to each BAR in a document.
Is there any reference for that?
Address assignment to BAR is done by host system/software. During enumeration, if the host find the devices uder the PCIe bus, BAR in the device is given the unique BASE address in the PCIe bus system. For example, even if two of the same board are plugged on the bus, each BAR has the different address.
Driver should find your two boards and obtain each of the bar and address range.
This is a fundamental behavior and the PCI Express base specification, PCI-SIG describes.
