Observer ndnsoulja
XDMA stream data to multiple masters
Any help would be appreciated!
Hi, I'm trying to route the XDMA streaming data to multiple aurora cores via the axis interconnect. Is this possible? How will I direct my data to aurora_64b66b_0 vs aurora_64b66b_1?
Observer ndnsoulja
Re: XDMA stream data to multiple masters
@ebrahimm
could you give some input?
Participant aforencich
It seems that the XDMA core does not provide the TID sideband signal, so it is not possible to use this signal for routing through an interconnect.  However, it should have the ability to enable more streaming interfaces, so what you should be able to do is turn on a second interface and then set up the interconnect to route each interface to take care of the rest.  Or possibly remove the interconnect completely.
