Xapp1052 Linux Driver compilation
I am Working on xapp1052, with ISE 13.4 and Centos version 5.7 (kernel ver. 2.6.18-274.18.1.el5 )? I am following the procedure given in xapp1052, when i try to run ./run_bmd.csh, It complains about an missing file named  "xbmd.ko"
here is the log of linux command
./run_bmd.csh
gtk-builder-convert xbmd_app.glade xbmd_app.xml
make: gtk-builder-convert: Command not found
make: *** [all] Error 127
crw-r--r-- 1 root root 241, 1 Mar  3 15:08 /dev/xbmd
+ /sbin/insmod xbmd.ko
insmod: can't read 'xbmd.ko': No such file or directory
Have any body else got some problem like this?  This file is called in load_driver file. Here is the contents of the load_driver file :
#!/bin/sh -fx
Is there some work around on this problme? Any help would be highly appreciated.
Best Regards,
Uzair
Tags (2)
"gtk-builder-convert" is a command associated with gtk development. Try looking for something labeled "libgtk-dev" or something similar and install that package. Your package manager (I think it's yum) may have an option to search package repositories for that file name.
