dpeti
Xapp859 fifo interface
I would like to ask some help regarding this PCI Express DMA controller.
I'd like to replace the DDR2 MPMC interface with NPI interface, but I stucked a little bit:
As a first step I wanted to fool the DMA controller with constant "FIFO" data, as automatically ACKing read and write requests, and signaling NotEmpty Read and NotFull and AlmostFull Write FIFO-s.
I've put KEEP property to all signals to debug it with chipscope.
reg iack;
reg eack;
reg [2:0] dmastate;
reg [127:0] idata;
reg [127:0] edata;
assign pause_read_requests			= 0;
assign ingress_data_ack = iack;
assign egress_data_ack = eack;
assign egress_data = 128'hABCD0123ABCD0123ABCD0123ABCD0123;
assign ingress_fifo_status = 0;
assign egress_fifo_status = 3'b100;
localparam IDLE  = 3'b000;
localparam LOADE = 3'b001;
localparam LOADI = 3'b010;
localparam DONE  = 3'b011;
always @(posedge trn_clk)
	begin
	idata <= ingress_data;
	edata <= egress_data;
	end
begin
	if (trn_reset)
		begin
			dmastate <= IDLE;
			iack <= 0;
			eack <= 0;
		end
	else
		begin
			case (dmastate)
			IDLE:		begin
							iack <= 0;
							eack <= 0;
							if (ingress_data_req)
								begin
									dmastate <= LOADI;
									iack <= 1;
								end
							else if (egress_data_req)
								begin
									dmastate <= LOADE;
									eack <= 1;
								end
							else
								begin
									dmastate <= IDLE;
								end
						end
			LOADE:	begin
							dmastate <= DONE;
							eack <= 0;
						end
			LOADI:	begin
							dmastate <= DONE;
							iack <= 0;
						end
			DONE:		begin
							dmastate <= DONE;
							eack <= 0;
							iack <= 0;
						end
			default:	begin
							dmastate <= DONE;
							eack <= 0;
							iack <= 0;
						end
			endcase
		end
end
The PC recognises the HW and successfully installs the driver, but when I start the program (wd910_csharp_capp859.exe) first it does nothing (so I kill it with task manager) and then it says that read start bit set, so I cannot run read DMA.
During chipscope debugging I've found that during the first program start, somehow it starts a Read DMA request, but it doesn't complete (addresses is not increasing, first address just loaded, and then it does nothing).
You can find a chipscope debug window attached.
dpeti
The code above is a little bit buggy, but I debugged it, and the problem probably will be in the read request module.
After starting the program, it sends a read dma signal to the core, and the core generates the following read requests (and it doesn't get any completion packet for it):
0000 2020 0000 00FF        0850 D000 0000 0000 - read request (trn_td)
0 00 00000 0 000 0000    R,MemoryReadRequest(Fmt00,Type00000),R,TC(BestEffort000),R
0 0 10 00  0000100000    TD(NoDigest0),EP(NotPoisoned0),Attr(RelaxedOrdering1,HwEnforcedCahceCoherencyExpected0),At(UntranslatedAddr00),Length(0x20)
0000000000000000    Requester ID
00000000 1111 1111    Tag, LastDW BE, 1stDW BE
0000100001010000    Address
1101000000000000    Address
0000000000000000    Address
Is it correct that the Requester ID is zero?!
I think it should be come from the cfg_{bus,device,function}_number...
Someone confirm it, please!
Thank you!
dpeti
Ok, it was user error (as usual)
I havent noticed the pcie_id inputs :)
