srhodgetts
Xilinx PCI Express DMA Drivers and Software Guide 65444 nonblocking functionality
I posted this in Embedded Systems/Embedded Linux but I haven't had any replies. https://forums.xilinx.com/t5/Embedded-Linux/Xilinx-PCI-Express-DMA-Drivers-and-Software-Guide-65444/td-p/922220
I think this might be a better location, can anyone help me?
The Xilinx PCI Express DMA Drivers provided here https://www.xilinx.com/support/answers/65444.html work pretty well but there appears to be some missing functionality for nonblocking reads.  I'm using Xilinx_Answer_65444_Linux_Files_rel20180420.zip with Linux Centos 7 and have enable_credit_mp=1.  I have PCIe streaming setup from the FPGA, this works when there is data, but falls apart when reading and 0 bytes are returned.
In the driver there is no implementation of file_operations .poll  in cdev_sgdma.c which would be used by sys/select or sys/poll.  So the file descriptor is always set in currentReadFdSet  for the following select() call in software.  A timeout was expected here when no data was available as currentReadFdSet only contains one fd for the /dev/xdma0.
 select ((nsfd + 1) , &currentReadFdSet, NULL, NULL, &timeoutPeriod)
Secondly nowhere in the code are the file->f_flags evaluated.  There should be checks for O_NONBLOCK in the read functionality and the driver should return -EAGAIN when there is no data on a nonblocking read.
Is the driver setup for nonblocking operations?  because it appears not to be the case.
I ran an experiment using this website (files are attached) http://www.sharetechnote.com/html/Linux_DeviceDriver_Programing.html
If I comment out the testdriver_poll from file_operations like this, then select always returns true and it tries to read the data when none is available.
static struct file_operations testdriver_fops =
.owner = THIS_MODULE,
.open = testdriver_open,
.release = testdriver_close,
.read = testdriver_read,
.write = testdriver_write,
// .poll = testdriver_poll
If it is in place I only read data when it is available, the check for NONBLOCK in the read code when bytes=0 is not seen.  So this seems confirms my hypothesis with the Xilinx driver.
Thanking you in advance,
Stephanie
srhodgetts
I did try to implement a function in cdev_sgdma.c for the driver but this corrupts the Linux kernel, so it's very hard to debug.  I think I have a chicken and an egg situation with the following code.  I want to check the engine for certain conditions to see if the read will block but the engine transfer is only setup when a 'read' is called so I believe I'm accessing null pointers and hence the code doesn't work.
There is char_events_poll function in the xdma/cdev_events.c file which is very similar to the code below.  I have MSI interrupts enabled which don't seem to trigger the cdev_events_poll or do I need to disable the cyclic buffer for this to work?
unsigned int char_sgdma_poll(struct file* file, poll_table *wait)
struct xdma_engine *engine;
struct xdma_cdev *xcdev = (struct xdma_cdev *)file->private_data;
unsigned long flags;
unsigned int mask = 0;
int rv;
struct xdma_transfer *transfer;
struct xdma_dev *xdev;
pr_info("char_sgdma_poll: begin\n");
rv = xcdev_check(__func__, xcdev, 0);
if (rv < 0)
return rv;
engine = xcdev->engine;
BUG_ON(!engine);
BUG_ON(engine->magic != MAGIC_ENGINE);
if (engine->streaming && engine->dir == DMA_FROM_DEVICE) {
xdev = engine->xdev;
BUG_ON(!xdev);
transfer = &engine->cyclic_req->xfer;
poll_wait(file, &transfer->wq, wait);
spin_lock_irqsave(&engine->lock, flags);
if (engine->rx_head!=engine->rx_tail ||engine->rx_overrun) {
  mask = POLLIN | POLLRDNORM; /* readable */
spin_unlock_irqrestore(&engine->lock, flags);
dbg_tfr("char_sgdma_poll: end\n");
return mask;
srhodgetts
This post has had no response for over two months. Frankly Xilinx support has been terrible, I have even been through a third party FAE this has been a pulling teeth process.  I was hoping the forum would at least get a response from the community.
Am I doing something wrong with the driver to setup nonblocking or is the lack of response confirmation that this is a blocking driver only?
venkata
Hi @srhodgetts,
The driver does NOT support non_blocking mode. If you are trying to modify the driver to enable it, we currently do not know if there is an easy way to do it.
We are reviewing to see if the driver can be updated in a future release to support non_blocking mode.
bscherer
Hello @venkata
Is there any update on the non blocking functionality by now?
