arotenst
Xilinx solution for PCIe core + DMA + (AXI-Lite + AXI4 (+ AXI4))
I am planning to use Xilinx PCIe core (for the first time) with Kintex Ultrascale.
I have several dummy questions:
Is it a glue less (or almost glue less) way to hook up PCIe core (PCIe x4 or x8 Gen2 or 3, if this matters) with DMA and the combination of AXI-Lite + AXI-4?
In a future I would need more than one full AXI-4 (along with the AXI-Lite) to hookup to the same PCIe interface. Is such combination (will it be) supported by Xilinx?
Could you help with useful links?
Thank you.
venkata
Hi @arotenst ,
Can you refer to XDMA IP? Please refer to PG195 (https://www.xilinx.com/support/documentation/ip_documentation/xdma/v4_1/pg195-pcie-dma.pdf) and IP GUI for the available options.
