zwilcox
ZCU102 as root not detecting endpoint
I'm attempting to set up the ZCU102 as a complex endpoint.  I followed the instructions for AR# 71439 for setting up the ZCU102 for a Gen2 x4.
However, I've attached three PCIe devices, an AC701 with the example PCIe project, a Insignia™ - 2-Port USB 3.0 PCI Express Interface Card and TP-Link 10/100/1000Mbps Gigabit Ethernet PCI Express.
However with both devices, when I run lspci, I only see the complex root and not the roots.
I even tried using the BOOT.bin and image.ub provided by AR# 71439.
I'm not sure what I'm doing wrong :(  Any help?
Edit: I should probably mention I'm using petalinux 2018.3
zwilcox
Hi @venkata !
I get the same result.  I was using pentalinux 2018.2.  I migrated to 2019.2 and the issue was resolved.
venkata
Hi @zwilcox
If you do a warm reboot of ZCU102 board without powering off the end point boards, what do you observe?
zwilcox
Hi @venkata !
