jimmy9137
ZCU104 PCIe Interface
To whom it may concern.
Hi, I'm working on PyTorch offloading to ARM processor in ZCU104.
Currently, I'm considering that I could offload some workload to the ARM processor via PCIe interface.
Anyway, I'm wondering if there is any document that ZCU104 can be connected to host PC (desk top or server host PC)
I attached a snapshot that the architecture of ZCU104 that caused me to curious about how I can attach it to my host PC
I would appreciate any help or documents
Thanks in advance
garethc
Hi @jimmy9137
First I would recommend that you take a look at the PCIE and CPM - Useful Resources post at the link below.
https://forums.xilinx.com/t5/PCIe-and-CPM/PCIE-and-CPM-Useful-Resources/td-p/1079558
Now for what you want to do the ZCU104 board is not ideal as it does not have PCIe fingers or connector and you will need a FMC PCIE connector to achieve this. AR:72076 details a EP example with an UltraZed board which may help you.
AR:72076 - Example design with PL-PCIe Root Port in the ZCU106 and PS-PCIe Endpoint in UltraZed
https://www.xilinx.com/support/answers/72076.html
Below is some supporting documents.
https://www.xilinx.com/support/documentation/selection-guides/zynq-mpsoc-kit-selection-guide.pdf
https://www.xilinx.com/support/documentation/boards_and_kits/zcu104/ug1267-zcu104-eval-bd.pdf
https://www.xilinx.com/support/documentation/boards_and_kits/zcu106/ug1244-zcu106-eval-bd.pd
Gareth
Versal Blogs
