Visitor jcrash29
ZCU106 PS PCIe
Is the ZCU106 board able to use the PS PCIe? Are the PS pins connected to the PCIe?
Any example of using it?
Re: ZCU106 PS PCIe
zcu106 board has PCIE interface from the PL section(PL GTH)
you can check the user guide
https://www.xilinx.com/support/documentation/boards_and_kits/zcu106/ug1244-zcu106-eval-bd.pdf
In case you are looking for implementing root port in zcu106, check the following link
https://www.xilinx.com/support/answers/72076.html
Visitor jcrash29
Re: ZCU106 PS PCIe
Does that mean that the PS PCIE is not connected?
Re: ZCU106 PS PCIe
zcu106 has the PS PCIE
You will need to use the MPSOC and select IO interface with PCIE option on
Visitor jcrash29
Re: ZCU106 PS PCIe
I have set the Zynq MPSOC to use the PCIe. (I had to disable the Display Port to do this). However I still am having trouble determing from the schematic if the default pins the board selects for PS_PCIe are connected to the PCIe slot on the board.
