Voyager
Voyager
ZCU106: XDMA PCIe end of packet
I am developing video frame buffering on Ubunut host Via PCIe from Xilinx board (Test pattern generated). The IP used in this case is XDMA.
I tried to use the concept of dynamic linking. the FPGA is sending tlast correctly but
1. For buffer defined the end of packet is set
2. when there is loop back to first buffer from last (i.e. descriptor link to the first descriptor) then the end of packet is not available, even though the FPGA is sending tlast signal.
Can someone please guide me to the solution or implementation for video frame buffering for  XDMA.
thank you in advance
Best regards
Re: ZCU106: XDMA PCIe end of packet
Can you please provide a block diagram of your design? It can help to understand the issue better.
Voyager
Voyager
Here is the block diagram
See ttachment for setting of DMA.
I can see Tlast signal send from sampleGenerater block at the last packate of 256bit (tvalid ='1' and tready='1'), but this is not recognized as EOP by DMA or driver in PC.
Best regards
Are you setting EOP bit in the last descriptor in which end of the packet needs to be specified? Please check Table 2-5 of PG195.
