rajesh.zoho
Zc706 PCie Issue
Hi, I'm using zc706 board. in that PCIe, i'm trying to access both Receiving and Sending simultaneously with some fixed latency.  But in real case, Tx is send some unkown data while receiving time, then closer to Rx end time, real Txdata is going in Tx line. can anyone clear it. why Rx and Tx not doing parallel. what is the unknow data formate. i will attached some screen short for your reference.
Thanks & Regards
Rajesh M
venkata
Are you expecting both Tx data and Rx data to match on the same clock cycle?
