Zynq PCIe reference clock specification
   what is the min/max differential voltage specification for the PCIe reference clock input to a Zynq based PCIe Endpoint.?
    Elwyn
hi @hughese
you are welcome.
if you are using 7015, then Table 86 in DS187 applies.
Boris
hi @hughese
if you are using Zynq Ultrascale+, you can refer to ds925 Table 97 for valid voltage range of PCIe ref clock
http://www.xilinx.com/support/documentation/data_sheets/ds925-zynq-ultrascale-plus.pdf
if you are using Zynq-7000 devices, you can refer to Table 90 in ds191 (XC7Z030-XC7Z045) or Table 86 in ds187 (XC7Z010-XC7Z020)
http://www.xilinx.com/support/documentation/data_sheets/ds191-XC7Z030-XC7Z045-data-sheet.pdf
http://www.xilinx.com/support/documentation/data_sheets/ds187-XC7Z010-XC7Z020-Data-Sheet.pdf
Boris
  perfect - thanks!
  I had found a lot of generic values but just needed to confirm the 7015 specs.
    Elwyn
hi @hughese
you are welcome.
Boris
