Newbie zinzolin@
ZynqMP PL PCIe Root Port VIVADO project
Hello PCI Express Community,
I am interesting by the ZynqMP Linux PL PCIe Root Port exemple design described on the xilinx wiki page
http://www.wiki.xilinx.com/ZynqMP+Linux+PL+PCIe+Root+Port
I would like to know if it exists a VIVADO project ready for test to make some evaluation of this exemple design on a ZCU106 hardware.
I would like to know the reference of the Root port FMC used for the hardware setup.
Sincerely,
Lio
Re: ZynqMP PL PCIe Root Port VIVADO project
Hi zinzolin@,
We do not have a reference design available at this time for PL Root Port in the ZCU106.  Based on the known issues, I would highly, highly recommend starting this design in 2018.1 when PetaLinux is available.  The setup can be a bit tricky, so if you have Xilinx support via an FAE I would engage them early.   We are working on a "Tips and Tricks" guide for setting up the solution, and I can post back once that is available.
Using 2018.1, you will avoid a number of known issues and having to patch the driver.
