about
Advisor evgenis1
Advisor
Re: about zynq pcie
Hi @kaesar ,
Your IBERT test only shows the state of the Rx link from PCIe device to FPGA. The state of Tx link from FPGA to the device is unknown, and might be causing the issue.
There is a signal called cfg_ltssm_state[5:0]. It's an output from PCIe core, and very useful for debugging various issues. If PCIe link is good, this signal should be in 'L0'. If there are signal integrity issues, the link would periodically go to 'Recovery' for a few microseconds, then back to 'L0'. It might be that in your case it never reaches 'L0'. So it's worth taking a look at cfg_ltssm_state[5:0].
Evgeni
Re: about zynq pcie
Advisor evgenis1
Advisor
Re: about zynq pcie
Hi @kaesar,
Another thing to check is PERST# coming into PCIe controller. Make sure it's not active.
Evgeni
Re: about zynq pcie
Re: about zynq pcie
Have you checked the rxelecidle and txelecidle
txelecidle is always asserted it means it is not able to detect the host
it could be an issue with connecttion (tx/rx swithed for example)
or you can try to bypass the detection by modify the code in the pipe_wrapper file
for example
Add the following
    wire        [(PCIE_LANE*3)-1:0]        int_RxStatus;
    reg          [(PCIE_LANE*3)-1:0]       reg_RxStatus;
   always @*
   begin
   if (PIPE_TXDETECTRX)
     reg_RxStatus <= 24'b011011011011011011011011;
   else
     reg_RxStatus <= int_RxStatus;
   end
  assign gt_rxstatus = reg_RxStatus;
   // Change the following
  .GT_RXSTATUS                    (gt_rxstatus[(3*i)+2:(3*i)]),
   // to
  .GT_RXSTATUS                    (int_RxStatus[(3*i)+2:(3*i)]),
Or you need to follow AR56616
Re: about zynq pcie
Re: about zynq pcie
Re: about zynq pcie
it means  the link patiner has detected first 2 lanes but the FPGA has not  detected the link patiner
Re: about zynq pcie
Please run set_property  is_locked true [ get_files xxx.xci ]
if there is a subIP inside, you will run the same for the subIP
edit the files in other text editor, and reload them into vivado
