10-09-2017 09:33 AM
I am trying to use the DMA/Bridge subsystem for PCI Express in Vivado 2017.2.
At first, I wanted to instantiate an example design for the VC707 board using the AXI Stream interface and the full PCIe x8 connectivity. The steps I follow are:
create new project for VC707 > create block design > add PCIe DMA core > run block automation > select x8 and AXIS options within the block options > (right click on block) Open IP Example design
While on previous versions of Vivado this worked and opened the example design with the settings I wanted, with version 2017.2 I get the following error messages
# generate_target open_example [get_ips xdma_0] ERROR: [IP_Flow 19-3461] Value 'BAR_0' is out of the range for parameter 'Pf1 Msix Cap Table Bir(pf1_msix_cap_table_bir)' for BD Cell 'xdma_0' . Valid values are - ~, 0, ~, 1, ~, 2 ERROR: [IP_Flow 19-3461] Value 'BAR_0' is out of the range for parameter 'Pf1 Msix Cap Pba Bir(pf1_msix_cap_pba_bir)' for BD Cell 'xdma_0' . Valid values are - ~, 0, ~, 1, ~, 2 INFO: [IP_Flow 19-3438] Customization errors found on 'xdma_0'. Restoring to previous valid configuration. ERROR: [IP_Flow 19-3461] Value 'BAR_0' is out of the range for parameter 'Pf1 Msix Cap Table Bir(pf1_msix_cap_table_bir)' for BD Cell 'xdma_0' . Valid values are - ~, 0, ~, 1, ~, 2 ERROR: [IP_Flow 19-3461] Value 'BAR_0' is out of the range for parameter 'Pf1 Msix Cap Pba Bir(pf1_msix_cap_pba_bir)' for BD Cell 'xdma_0' . Valid values are - ~, 0, ~, 1, ~, 2 INFO: [IP_Flow 19-3447] Customization errors found during restoring IP 'xdma_0' to previous valid configuration. ERROR: [IP_Flow 19-3439] Failed to restore IP 'xdma_0' customization to its previous valid configuration. ERROR: [IP_Flow 19-98] Generation of the IP CORE failed. Failed to customize IP 'xdma_0'. Failed to apply user parameter values. INFO: [Common 17-206] Exiting Vivado at Mon Oct 9 18:28:26 2017... ERROR: [Common 17-69] Command failed: Unable to open example project; see previous messages.
and no example design.
Also, trying with different boards or options (including those related to MSI-X) leads to the same error.
What is wrong in my block design?
10-19-2017 01:25 AM
I have the same problem, did you succeed to resolve it?
cheers
