savijeet21
data register
while using the PCi express could you please tell me where the data is being stored in a register  if at all during the read and write operations? also in which .v file is this register mentioned?
i hae found these lines in the BMD_EP_MEM_ACCESS file..... do these represent the databus?
     *  Extract current data bytes. These need to be swizzled
     *  memory storage format :
     *    data[31:0] = { byte[3], byte[2], byte[1], byte[0] (lowest addr) }
    wire  [7:0]      w_pre_wr_data_b3 = pre_wr_data[31:24];
    wire  [7:0]      w_pre_wr_data_b2 = pre_wr_data[23:16];
    wire  [7:0]      w_pre_wr_data_b1 = pre_wr_data[15:08];
    wire  [7:0]      w_pre_wr_data_b0 = pre_wr_data[07:00];
     *  Extract new data bytes from payload
     *  TLP Payload format :
     *    data[31:0] = { byte[0] (lowest addr), byte[2], byte[1], byte[3] }
    wire  [7:0]      w_wr_data_b3 = wr_data_i[07:00];
    wire  [7:0]      w_wr_data_b2 = wr_data_i[15:08];
    wire  [7:0]      w_wr_data_b1 = wr_data_i[23:16];
    wire  [7:0]      w_wr_data_b0 = wr_data_i[31:24];
luisb
I would recommend to look in the BMD_EP_MEM.v file.  Look at the case statement on the a_i signal.  Hope this helps.
savijeet21
thanks. will do the same
tenantfile
Thanks for giving this knowledge. I was also trying to do this. It works.
