end point for pcie(IP core),max payload size's problem
when cpu send  data to endpoint(size>256Byte), the endpoint would not be found. I failed to see the ID number.IP's max payload size is set to 512B.
why does this happen?
I am not sure if the IP core generation is wrong. this ip  don't support the ASY symbol generation.the maxpayload reg is always 0.
I guessing that within CoreGen you set the Max Payload Size to 512, but this doesn't mean that the system is set to 512.
By selecting 512 within CoreGen, you're setting the Device Capabilities Register MPS to 512.
The Device Control Register is written to by the Root.
The root determines what to write to the endpoint's Device Control Register once it finds the lowest MPS on the system.
Hope this helps.
-Luis
