Observer zdzlin
how to constraint the refclk?
Hello,all:
     Now I'm trying to use K7 to implement a Pcie X4Gen2 design, after I generate the IP in Vivado, I tried to
connect the base port, refclk,PCIe lans, reset to the too level.when the implemention finished, there pops two
error message,shows that the refclk_p and refclk_n's IO standard had not been defined. But I checked the PG054.pdf, and could not found an example two define the iostandard of the refclk?
    Could anybody help me to solve this problem or told me where could I found the answer?
Thanks a lot.
Re: how to constraint the refclk?
Which vivado version are you using?
