how to control pcie reset input (sys_rst_n) and xdma bridge's axi_aresetn
All,
Because we are using Xilinx PCIE driver, so from SW point of view, how to control pcie reset input (sys_rst_n) and xdma bridge's axi_aresetn??
the FPGA is Virtex U+, by using Xilinx PCIE driver, is it possible to assert/de-assert those two reset from upper level SW?
How to do it?
Thank you very much!
Best,
Re: how to control pcie reset input (sys_rst_n) and xdma bridge's axi_aresetn
Hi, zan_zhan@amat.com
sys_rst_n is input to XDMA and axi_aresetn is output from the IP.
sys_rst_n is recommended to be connected from the edge connector and controlled by the Root Port.
