xikun.dai
larger max_payload_size has lower performance
Hi, we have 2 develop board with fpga device v7-690t-ffg1761,and implement a pcie gen3 x8 rp on one board, implement a pcie gen3 x8 ep on other borad, buiding the connection as below diagram use rp applicaton interface s_axis_rq_* to send data to ep, and ep receive data with application interface m_axis_cq_*, if set max_payload_size=128byte,the performance is about 36Gbps, but if we set max_payload_size=512byte, the performance is about 33Gbps,larger max_payload_size get lower performance.
xikun.dai
Hi, we have 2 development board with fpga device v7-690t-ffg1761. and implement a pcie gen3 x8 rp on one board, implement a pcie gen3 x8 ep on other borad, buiding the connection as below diagram: use rp applicaton interface s_axis_rq_* to send data to ep,and ep receive data with application interface m_axis_cq_*. if set max_payload_size=128byte,the performance is about 36Gbps, but if we set max_payload_size=512byte, the performance is about 33Gbps, larger max_payload_size get lower performance. BR Xikun
kotir
Hi ,
PCIe link bandwidth does not depend just on Max payload size.
Have a look at the below white paper.
http://www.xilinx.com/support/documentation/white_papers/wp350.pdf
KR
