ml506 to SSD Via PCIe
I have an SSD with PCIe interface and ml506 board,
I need to connect them together, is it possible? and how Do I do it?
Thanks for your help
Best Regards,
B.Romanous
we have the following XAPP to show how the V5 hardblock can be setup to support peer-to-peer connectivity.
http://www.xilinx.com/support/documentation/application_notes/xapp869.pdf
I personally do not recommend this.  I recommend using the Virtex-6 Root Port solution instead.  The V6 root port is documented much better.
Thanks a lot !
So my ml506 is the master and the ssd will be the slave
what about the connection medium that I need?
Is there a specific backbone that I should install these two boards on?
Best Regards,
B.Romanous
